4 wheel drive noise
lukey4x4
Re: 4 wheel drive noise
Post by lukey4x4 » Thu Oct 20, 2016 6:12 pm
Pm you jordi mate
lukey4x4
Post by lukey4x4 » Sat Oct 22, 2016 3:23 pm
alright guys back agen
so fitted the passenger side new cv today got everything back on n went to test it so put it in 4WD locked hubs turned right on lock and bang noise is still there doesn't seem as bad with the new 1 in so no harm done but a could sware the noise is coming from front drivers side , anyways I took the front prop off and it had more play than I though at tbox end so will get that sorted , and whilst I took it off I span the bit on the tbox and it sounded lyk a machine gun could this be my noise ??? nackered bearing ??? is this just as easy as a bearing change or is it tbox out and rebuild or a new 1 , not sure what to do now thanks lads
lukey4x4
Post by lukey4x4 » Sat Oct 22, 2016 9:52 pm
anyone local fancy lyk taking a look for me after seeing some of the prices of a secondhand tbox don't fancy lyk changing sumit a don't need to , thanks
lukey4x4
Post by lukey4x4 » Wed Oct 26, 2016 12:54 am
Hi guys hopefull tomoz all my little noise problem will be fixed when i get everything back together just got my prop shaft back today new ujs on both ends so will get that on tomoz both cv joints are brand new and r already fitted av got my recon starter to go on and also got my finger out and took that gearbox out and a few bits swopped over onto new one which seems pritty good ,got my cb stuff to fit and get my snorkel on n am ready to go agen n hopefull no clonking noise , i was watching a suzuki sj vid on youtube and out of surprise it sounded like the yellow van sj had the same noisething i am having http://youtu.be/YeOlR_bGeAQ skip to 6 mins in its after the trayback sj trying to get up the lil bank , thanks guys
lukey4x4
Post by lukey4x4 » Thu Oct 27, 2016 5:34 pm
Well after getting most of the work done yesturday all i needed todo today was fit the startermotor and adjust to clutch cable abit n was ready for test so locked the hubs put it in 4WD and put it on lock and drove round my street not a single noise so happy days not sure if it was cv or propshaft but all brandnew now soo piece of mind , thanks for help lads , is there a way i can check the hubs r locking and unloking do i just jack 1 wheel up at a time in 4WD and see if it lock and unlocks ? Thanks
Post by Jordi » Thu Oct 27, 2016 10:50 pm
lukey4x4 wrote:Well after getting most of the work done yesturday all i needed todo today was fit the startermotor and adjust to clutch cable abit n was ready for test so locked the hubs put it in 4WD and put it on lock and drove round my street not a single noise so happy days not sure if it was cv or propshaft but all brandnew now soo piece of mind , thanks for help lads , is there a way i can check the hubs r locking and unloking do i just jack 1 wheel up at a time in 4WD and see if it lock and unlocks ? Thanks
Jack the front axle up and with both hubs locked when you spin one wheel the other should spin, most likely the other way.
With only one hub or no hubs locked when you spin one wheel the other should not move.
lukey4x4
Post by lukey4x4 » Thu Oct 27, 2016 11:24 pm
Cheers jordi mate will give it a try
