Page 4 of 85
Re: Samurai Remodelling
Posted: Tue Apr 20, 2010 1:41 pm
by d86
Jordi wrote:Yeah, its taken me long enuf to get it done.
It's a labour of love. Sum refer to it as a sickness.
I HERE YOU THERE BROTHER.......
tony
![Razz :P](./images/smilies/icon_razz.gif)
Posted: Tue Apr 20, 2010 4:01 pm
by Tramp
Jordi wrote:
I do have a red shock boot for this damper too but havn't fitted it yet.
I recognise that, Ive got one for mine, but mines pro-comp
I would say you are better leaving the boot off this one, as they can fill up with mud and crap and it ends up bathing the shaft in grit which makes the seal go on the unit,
Luke
Posted: Sat Apr 24, 2010 10:58 pm
Wow, ppl of SCUK, we have a bumper. Oh yes, custom design and fabricated by me!!! Take a look as the craftsmanship.
Yes, it's a piece of box section.
![IMG_0063.JPG](./download/file.php?id=951&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0063.JPG (68.9 KiB) Viewed 12160 times
Im rather proud of it, not quite sure where the lights are gonna go tho, may just mount them on the back of the cab.
It's not all good news tho. I have plumbed up the brakes and started bleeding them only to discover that the n/s front piston is peeing fluid out. So tomoz it will be stripped down to check the seal and if needs be order the rebuild kit from brakes int.
Posted: Sat Apr 24, 2010 11:02 pm
Also thought I would share my rather funky welding mask. One of those auto darkening jobbies. With a solar panel to charge its battery as u weld. ebay job, £35 i think. Its pretty good and makes it a damn sight easier than my old mask as it was so dark u cud barely see even when u were arcing. I was trying to get the skull image but it was £10 more even tho is was same mask different image.
![IMG_0064.JPG](./download/file.php?id=952&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0064.JPG (38.69 KiB) Viewed 12164 times
Posted: Sun Apr 25, 2010 7:38 pm
Well another day spent not exactly rebuilding but certainly working on it. Back bumper still looks swell. Stripped down both front calipers and cleaned out a pint of crud. Both seals seem fine and i once again bled the system this time with slightly better outcome. There still air in the system but it is pressurising and the seals seem to be holding. The piston boots have gone the journey tho.
As my other post says im going to run 31s without a lift and they seem to foul the bulkhead. So any advice on virtual lifts will be welcomed. Soon as i get the tyre issue resolved ill b bolting the front wings back on and whipping her down for an MOT.
Posted: Fri Apr 30, 2010 10:49 pm
Ok, So based on advice from my other post I have now started attacking the bulkhead with the large grinder and also thought whilst it was plugged in i'd have a chop at the wing too. I've chopped more out since the foto was taken but I think it shows the idea. All i want to know is which Suzuki designer had the idea to make the bulkhead such an odd shape??? What was wrong with flat and smooth???
![IMG_0069.JPG](./download/file.php?id=966&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0069.JPG (188.81 KiB) Viewed 12098 times
![IMG_0067.JPG](./download/file.php?id=965&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0067.JPG (163.15 KiB) Viewed 12095 times
Seen as the bulkhead investigation was doing my knut I thought id sit my 'new' wing on and try her for size (complete with new 'bit' also wedged in place for effect. I hope its gonna look tidy, but we'll see.
![IMG_0065.JPG](./download/file.php?id=967&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0065.JPG (193.53 KiB) Viewed 12093 times
Posted: Fri Apr 30, 2010 10:51 pm
![IMG_0066.JPG](./download/file.php?id=968&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0066.JPG (162.64 KiB) Viewed 12095 times
To avoid the sharp edge issue im gonna get sum rod probs 5mm and use it to edge the wings.
Posted: Sat May 01, 2010 10:24 pm
More photos for you all to be amazed at my welding. In my defence, its a lot better than it was.
![IMG_0081.JPG](./download/file.php?id=972&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0081.JPG (114.81 KiB) Viewed 12068 times
![IMG_0086.JPG](./download/file.php?id=973&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0086.JPG (108.87 KiB) Viewed 12066 times
![IMG_0080.JPG](./download/file.php?id=974&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0080.JPG (105.54 KiB) Viewed 12066 times
Thats both bulkhead corners cut and plate tacked in. Hopefully, fingers crossed tomorrow i'll pull her outta the garage and give her a mini test outside the house just to make sure nothing fouls and get them welded up.
Posted: Sat May 01, 2010 10:28 pm
I've also cut both wheel arches out now and tried them for size.
![IMG_0072.JPG](./download/file.php?id=975&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0072.JPG (97.87 KiB) Viewed 12064 times
![IMG_0074.JPG](./download/file.php?id=976&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0074.JPG (92.26 KiB) Viewed 12062 times
![IMG_0075.JPG](./download/file.php?id=977&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0075.JPG (122.87 KiB) Viewed 12059 times
I'm pretty pleased with the days work and whilst not perfect progress has been made. I also managed to rope an assistant into pumping the brake pedal whilst i finally got the brakes all bled properly and fitted new pads to go with the new shoes and pistons. I have new discs but wont be fitting them until MOT so as they dont get corroded.
Posted: Sat May 01, 2010 10:32 pm
As mentioned above today was fairly productive. Using the below tools to cut and 'adjust' the plate to fit.
![IMG_0083.JPG](./download/file.php?id=978&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0083.JPG (114.76 KiB) Viewed 12063 times
There was however one slight 'catching fire' incident. No thankfully it wasnt the Sammy it was my leg. Luckily I had my gauntlets on and just damped it out.
![IMG_0084.JPG](./download/file.php?id=979&sid=15cb60ce7776233fc407f0647a564e6c)
- IMG_0084.JPG (93.22 KiB) Viewed 12059 times
Roll on tomorrow!!!
