SU Carbs
Re: SU Carbs
Post by ScottieJ » Fri Jun 01, 2012 9:35 am
suzukisteve wrote:on the way home last nite i was thinkin bout twin su's.
has anyone herd of this or if it can be done on an sj?
http://forum.suzukiclubuk.co.uk/vi ... 13/t,3792/
Looks like a few pics have been corrupted though so I will upload them again at lunchtime.
suzukisteve
Re: SU Carbs
Post by suzukisteve » Fri Jun 01, 2012 10:38 am
ah nice, got a few other things to do first... mainly welding and paint!!
but deffo an sweet idea for the future!!
ill have to start a build thread when i finally start modifying!
cheers scott!
pickle power!
Jay18
Re: SU Carbs
Post by Jay18 » Fri Jun 01, 2012 12:59 pm
cheers Scottie might stick it on the bay and see if I can get something for it...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
silverfox
Re: SU Carbs
Post by silverfox » Sun Jul 15, 2012 11:42 am
That's SU HS2 (it has two vertical bolt holes and a 1.25" tube just like the SJ410) it will fit onto the SJ410 and is a smaller carb than the HS4 or HIF38. You need to make up a plate with 1.25" hole two vertical holes where the SU bolts on the two more to line up with the SJ's bolt holes. Use a alloy plate very a similiar thickness to the manifold spacer.
You will also have to cut the lugs on the float chamber to get that to stand upright.
Roger.
Jay18 wrote:ive got myself a SU carb for free and i havent a clue what type it is, anyone help?
on the plastic cap on the top it says AUC8103
on the littly aluminium plate it say AUD 40
would it fit my sj410? if not then what is the carb type so i can sell on ebay and hopefully buy the right one :D i know its a SU...
ianedwards
Re: SU Carbs
Post by ianedwards » Sat Jul 28, 2012 10:45 pm
So has any one come to a conclusion on what's the best setup for the 1.6 8v with su carb, bfm or bbz needle, just wondering which one to go for.
Ian
Ian. :)
Re: SU Carbs
Post by dan_2k_uk » Sat Jul 28, 2012 10:59 pm
Drove mine for the first time today on a BFM with a yellow spring and wasn't disapointed! :thumbup:
lazy rambler
Re: SU Carbs
Post by lazy rambler » Sun Jul 29, 2012 12:46 am
Can anyone explain what pipes go where on a HIF44, as you may know I'm part way through a 1.6 conversion and I'm unsure on how to 'plumb in' the SU.
Now a build in progress
Re: SU Carbs
Post by dan_2k_uk » Sun Jul 29, 2012 1:23 am
Will take a snap of mine tomorrow 4 you
ianedwards
Re: SU Carbs
Post by ianedwards » Sun Jul 29, 2012 1:45 am
Tidy, will have to have a look to see what's in mine, looking back there where pics at the start but they arnt showing any more.
Ian
Ian. :)
Re: SU Carbs
Post by Edweird » Sun Jul 29, 2012 1:58 am
If you've not bolted it on yet, slap a photo of the side of it on here and we can work out what everything is. Worked for me.
