Carburettor needs a service (And now the dizzy)
Re: Carburettor needs a service (And now the dizzy)
Post by Tramp » Fri May 13, 2011 7:46 pm
I'm glad you stuck with it, it wasn't such a big job after all was it? I hate the wittering bit, where you worry about doing a job before you get to it,
Post by ScottieJ » Fri May 13, 2011 9:49 pm
Nice work Ed :thumbup: and you didn't even need to drop the tank :rockin:
Post by Edweird » Fri May 13, 2011 11:32 pm
Edweird wrote:Fixed it.
Unfixed it. It's been fine for a few hours, but after working it hard for a while it's started coughing a bit like it initially did a few months ago. :argh:
Fixed my headlight problem though. The wiring had split and frayed completely about 2 inches away from the plug on the Red with white stripe wire, so dip beam didn't work. Replaced it with a cable from an old dyson. That should last a long while. :brows:
Post by Edweird » Sat May 14, 2011 10:58 am
Blew down the hose outlet again. There's a fair bit more crap collected in the filter after that last attempt, so I guess just keep blowing back until it stops doing it, and replace the filter as and when.
Post by Tramp » Sat May 14, 2011 12:37 pm
Edweird wrote:Blew down the hose outlet again. There's a fair bit more crap collected in the filter after that last attempt, so I guess just keep blowing back until it stops doing it, and replace the filter as and when.
yeah that is the best bet, if you keep doing it you will eventually clean it all out
Post by Edweird » Sat May 14, 2011 4:04 pm
Mum and Stepdad want to get a new tank for it. :er: I've been told to ask you guys some questions.
Apparently there's two types? Clip on or bolt on senders?
Do they have part numbers?
What are the dimensions approximately?
Is it just four bolts and undoing the hoses to take it off, or is there more to it than that?
Sounds a bit like overkill to me, but.... :|
Mine's the early pre-1984/5 version.
Post by ScottieJ » Sat May 14, 2011 4:41 pm
Is your sj jap or Spanish? Jap generally have screw in senders with 1 wire and Spanish have clip in and 2 wires I think.
I think that's theft right way around, might be best to drop it and look though, the most important bit is how many wires it has.
And yep 4 bolts, the hoses and sender wires and out it comes :thumbup:
Henry
Post by Henry » Sat May 14, 2011 6:41 pm
Count yourself lucky.
I went to hill and ditch a few years ago (sand quarry)
The tank is still around somewhere, 1/2 full of petrol and half full of sand :thumbdown:
You can make your sender fit the tank designed for the other sender (if you get me) I did do it once, ill find the tank and pop some pics up \ :tongue:
backattheranch
Post by backattheranch » Mon May 30, 2011 11:08 pm
hi im having similer problems with my sj 413 i belive it to be a standered carb and when the guy who i got it from got it it come with two extra carbs . so the guy sent it to the garage and had the carb stripped down and rebuilt but never made 2 much difference to it. on start up you can smell petrol in the air and sounds as if it only running on 3 cylinderes. then if it been stood for a little while you have to clean the plugs as they are covered in black soot. any help would be great thanks
