filling gearbox oil
Ginger_boy
Re: filling gearbox oil
Post by Ginger_boy » Fri Jun 03, 2011 5:13 pm
Edweird wrote:My brian is telling me that they're less likely to shear?
Got them on my diffs but hexangon plugs on the Gearbox. Found that alittle time digging all the dirt out of the 1/2" square holes and warming the surounding area up with a blow tourch works wonders undid a treat the last time I changed the oild in them.
As for the gearbox if memory serves the plug is the filler but the bolt just to the right of it is the oil level
Post by twiss » Fri Jun 03, 2011 5:22 pm
I guess it's to make sure you don't accidentally drain the gearbox oil onto your face while trying to top it up ;)
Ginger_boy
Post by Ginger_boy » Fri Jun 03, 2011 5:40 pm
twiss wrote:I guess it's to make sure you don't accidentally drain the gearbox oil onto your face while trying to top it up ;)
Its quite a tight squeeze between the trany box and the gearbox.
First time i did it i used those stupid little bottles of gear oil from halfords they where a bugger to put the oil in with. When I changed the oil this time i used a oil syringe with a piece of rubber tube attached, routed the pipe up into the anus didn't then have to keep crawling under with another shot of oil.
Post by twiss » Fri Jun 03, 2011 6:50 pm
I've just put a pipe on the end of the halfords bottle ;)
When you've squidged them enough times you can push quite a big up the pipe...
You can't have it that long though so you do still have to crawl around underneath
Smalljeep
Post by Smalljeep » Sat Jun 04, 2011 9:50 pm
i still havent drained it, i went underneath and seen grease nipples on the driveshafts and filled them with grease, forgetting about the gearbox.
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
