If you hand over lots of money.........................Jordi wrote:If Scott gives me his. You can have mine.Anton wrote:I still think you should just give it to me...
Jordis 1988 Samurai (Re)Build
Money?
I still haven't quite grasped the concept of how that works yet. Its just numbers on a bank balance for 5 minutes once a week. People keep taking it all of me for some reason.
I'm home. Front gearbox oil seal done!
Rear diff is weeping now though!
Another rare night at home through the week.
Gave the Zuk a pressure was off at work to reveal some additional drain holes i never knew where there. May have to address those at some point.
Exhaust isn't as bad as i thought. Just the mounting bracket rusted off. That will also weld up.
Been running quite lumpy on tick over, had a suspicion it was sucking extra air in between carb and manifold / manifold and block. Did some investigation with a tin of WD40 and it is between carb and manifold. So as soon as i get the sealant back from my Dad thats a nice quick fix.
Also gave the rad a damn good blast through and its running much cooler, haven't been any great distance to test it yet and it is also much cooler today. Time will tell on this one, signs are good though.
All in all nothing as serious as i thought, just a few minor jobs to do. Hoping to get the 410 front clip VL done and fitted, maybe even painted, by Wagtail.
- suzukisteve
- Suzuki Guru
well for a whole weekends off roading you seem to have faired well. not to much stuff to sort mate. I really hope I get a chance to see it first hand one day mate, shame I can't make it to wagtail this time round!
pickle power!
Woth the exception of running hot it went fine all weekend. Exhaust blow is nothing major.suzukisteve wrote:well for a whole weekends off roading you seem to have faired well. not to much stuff to sort mate. I really hope I get a chance to see it first hand one day mate, shame I can't make it to wagtail this time round!
I'm seriously thinking twin stainless vertical pipes now though!!!!
If im home early tomorrow or first thing saterday i'm going for a quote!
Need to get a quote. Thats all i'm saying.turbo-tom wrote:Go twin bud
Just been to the exhaust place. And decided on a wallet pleasing compromise.
The majority of the exhaust pipe is ok just rotten at the back and the silencer is rotten.
Going to have a cherry bomb!!!! Fitted underneath and then a stainless pipe up the back of the cab. So even when it does rust away again you won't see any on the outside.
Booked in for Sat 27th.
- suzukisteve
- Suzuki Guru
stuck in work while across the road my engine transplant is underway. its like torture
pickle power!
