Project back in black.
- robbie1985
Re: Project back in black.
i've been working to rid the car of rust, so have been busy with the wire brush, krust, and red oxide. before the really horrendous weather kicked in i managed to get some of the worst of the rust on the back end dealt with and also done the tank guard which came out really well, i finished it off with halfords truck bed paint i was a bit skeptical about it and to be honest i was really impressed, i'm probably gonna use it in the the car in the foot wells and the back of the truck once i have removed the rust and welded in good metal around the old seat belt mounts. i am gonna be buying a 3 inch body lift from b4v in the near future and whilst fitting that i will go through the hole chassis and under the body and do the same with any rust i find. tis all fun
- IMAG0521 (Small).jpg (182.64 KiB) Viewed 6153 times
- IMAG0522 (Small).jpg (169.67 KiB) Viewed 6153 times
- IMAG0523 (Small).jpg (213.78 KiB) Viewed 6153 times
- IMAG0524 (Small).jpg (161.44 KiB) Viewed 6153 times
- IMAG0525 (Small).jpg (154.32 KiB) Viewed 6153 times
- IMAG0527 (Small).jpg (133.55 KiB) Viewed 6153 times
- IMAG0528 (Small).jpg (126.49 KiB) Viewed 6153 times
- IMAG0529 (Small).jpg (141.35 KiB) Viewed 6153 times
- IMAG0530 (Small).jpg (144.45 KiB) Viewed 6153 times
- robbie1985
i am also looking for a set of bull bars like these, if anyone has a set that they want rid off?
- Picture011 (Small).jpg (80.21 KiB) Viewed 6152 times
Tidy job that mate fair play.
I literally spent 5 mins wire brushing my tank gaurd off then rollered some hammerite over it haha
- robbie1985
To be honest that's all I was gonna do it it, but I had the spray paint and wanted to se e what it came out like before I used in it the foot wells.
- donkeychomp
- robbie1985
Cheers donkey chomp, I am gonna drop the fuel tank out so I can get to the back of the crossmember and clean up the tank. I have a list the length of my arm of thing I wanna do under the car but can't take it off the road for long enough to do it all at once'
