- The Boss
Post
by ScottieJ » Mon Apr 04, 2016 8:25 am
Gilly_SJ wrote:Not be doing preloads haha I was thinking more of a windy gun off then back on. May do the diff if there is less chance of making a mess of it
If you did that on the diffs then don't expect them to last long!!! If the diff flanges come off then you at least need to fit a new crush collar, and in order to reset the pinion bearing preload the diff needs to come out of the carrier.
As said, just Redrill the flanges, it's the quickest and safest option.
Gilly_SJ
Post
by Gilly_SJ » Mon Apr 04, 2016 12:50 pm
ScottieJ wrote:Gilly_SJ wrote:Not be doing preloads haha I was thinking more of a windy gun off then back on. May do the diff if there is less chance of making a mess of it
As said, just Re drill the flanges, it's the quickest and safest option.
Yeah that sounds a bit out of my comfort zone. Ill use the flange to drill the rear but the front still isn't on so I'll do it with my little jig i've made.
Gilly_SJ
Post
by Gilly_SJ » Fri Apr 08, 2016 9:13 am
drilled the rear and fitted up nicely but I noticed the prop seems to be almost fully compressed just stood at ride height. is there anyway to shorten it a touch or is it easier to move the rear axle back a smidgen.
- The Boss
Post
by ScottieJ » Fri Apr 08, 2016 10:22 am
Have you got pics, there's a chance it has a 410 rear prop, they are around 25mm longer than 413/samurai props.
Gilly_SJ
Post
by Gilly_SJ » Fri Apr 08, 2016 10:38 am
This anus is like Frankenstein's monster. Ill get some later when I get home. A friend has an odd Prop that wouldnt fit his 410 so that may be the right length.
I was hoping I could just tickle 10mm off the splines and call it a day,
- The Boss
Post
by ScottieJ » Fri Apr 08, 2016 12:55 pm
Personally I wouldn't, will be handy to keep if it ever gets a bit more suspension lift
Post
by Jordi » Sun Apr 10, 2016 5:36 pm
Or swap the longer prop for a Samurai prop with someone who could use it.
Gilly_SJ
Post
by Gilly_SJ » Sun Apr 10, 2016 9:30 pm
Had it out yesterday and no knocking over bumps etc so looks to be fine, brakes are taking a lot of bleeding and had to clean the master cylinder. Got some pedal feel now but it's still very low so need to look at that. The ratios seems to be helping, places I couldn't try unless in 2nd gear low I can now do in 1st so it's not bogging down as badly when all 4 get grip.
