I thought I'd update as I had a play today. I've not done much really and i feel a bit guilty for leaving it so long,
So I thought I'd tackle a few things today, the canvas roof has been annoying me it flicks up above the back window, while the body was off I put some glue under it and weighted it down, Also I started making the door handles not much technically to them but just fiddly to get them both to match!
Next The problem was still far to much flex, and some torque twist from the drive line, I tried correcting this using the standard plastic spacers that came with the shockers but there wasn't really enough, so I made 4 identical spacers to push the springs down and the suspension harder, I didn't make the spacers full length as only going 4/5ths of the way allows me to put extra spacers in to correct the torque twist. I don't think torque twist should be such an issue now because by tightening everything up the suspension isn't as forgiving,
here's the chassis with the spacers
and the springs and spacers, I used a bit of tubing I had laying around, luckily the inside diameter was spot on!
And the obligatory Twist shot, This is as much articulation as it has... Which is spot on! In the end the suspension is restricted by the spring spacers and rubber fuel line on the piston rod,
Now to the body and the spare wheel, I don't like it but it was the best I could do (1.9 landrover rim with an original MRC tyre) but it is way to big for what I want, Ideally I'd like another metal rim with a dirt grabber (so they all matched) But I don't want to pay for a set of 4 rims and some tyres for a wheel that I'm not even going to use! I'm sort of hoping some one else who has used these wheels and tyres will feel the same way about a spare and a buy a set then sell me one! Other than That I'm keeping my eyes out for a children's toy with similar sized wheels that I could use,
I put the body back on and glued on the door handles, I made a start on the wing mirrors to,
It still sits a little high at the front. Also Its still getting some torque twist,
What's left for me to do Externally (im not bothered about the interior)
The wing mirrors
Windscreen wipers
Windscreen/window surrounds
Locks
Door handle on the back door
Hinges
Spot lights - Any suggestions on ones I could steal form other kits?
Spare wheel
Fitting the leds for the lights
Luke
