SJ410 -1985 'Cabrio', engine rebuild
binge
Re: SJ410 -1985 'Cabrio', engine rebuild
Post by binge » Thu Mar 27, 2014 11:01 pm
Got back in my garage this evening with a clear head.
Cranked the heating up, stuck the kettle on, and had a good look at this engine.
Whipped all 4 pistons out. The rings and bores all look okay. Bores are a little shiney / polished for my liking, so thinking of new rings and a hone.
Shells are defo shot, can see the wear in them.
The crank, has some very light marks on it, but nothing too nasty. Can only feel a few of them if you really dig your finger nail into the marks.
I measured each journal on the crank with a vernier, vertically, and horizontally. And there was about 0.2mm difference in it. Is there a tolerance to go by with these engines?
I then wire wheeled the engine and head, and decided to go all classic-Mini on it, and give the engine a paint.
RS125 engine in the background, one of my other projects which has been pushed aside thanks to this SJ...
And ring gap, which is .013"
Ben
Post by donkeychomp » Thu Mar 27, 2014 11:21 pm
Nice work. Love the colour of that engine...can you tell me what paint you used? Looks like the same stuff on my bikes brake discs.
binge
Post by binge » Thu Mar 27, 2014 11:39 pm
Its just gold hamerite mate. Smooth finish.
Post by donkeychomp » Thu Mar 27, 2014 11:45 pm
Looks amazing...hope this engine works!
Ladaman
Post by Ladaman » Fri Mar 28, 2014 8:10 am
0.2mm out of round on a crank journal is massive!
I'm sure Darrell or someone will be along with the actual tolerance soon, but i'd have thought it should be around 1/10 of that figure.
Post by ScottieJ » Fri Mar 28, 2014 8:12 am
Nice work. It's not finished yet but you can find all the clearances in this thread.
http://forum.suzukiclubuk.co.uk/vi ... =13&t=3537
Ladaman
Post by Ladaman » Fri Mar 28, 2014 8:42 am
That table shows bearing clearances. Roundness of the crank will need to be a much smaller value than the clearance to work correctly.
binge
Post by binge » Fri Mar 28, 2014 12:04 pm
:oops:
Posted quite late last night, 0 was on the wrong side of the .
.02mm
Ben
Ladaman
Post by Ladaman » Fri Mar 28, 2014 5:22 pm
Well that's a lot more like where it should be.
I've had a look in the manual now, and this is what it says.
You're still double the tolerance, but that could just be measurement error, as we are talking very small amounts here.
If as you say the marks are very slight, I'd think the crank will be OK and just new shells needed.
gp7186
Post by gp7186 » Fri Mar 28, 2014 5:59 pm
You may bring this 0.02mm down if you measure with a micrometer as most vernier calipers have a tolerance of either 0.05mm or 0.02mm whereas most micrometers have a tolerance of 0.01mm
