Not striking up
The Bird Man
Re: Not striking up
Post by The Bird Man » Sun Nov 02, 2014 5:56 pm
So the valves need to be open not closed ? :S
Rhinoman
Re: Not striking up
Post by Rhinoman » Sun Nov 02, 2014 6:03 pm
If the valves on no4 are both open then no1 is at TDC and vice-versa. If it doesn't make sense then its probably best just to whip off the rocker cover and check that when you think no1 is at TDC both the valves on that cylinder are closed with a noticeable gap .
The Bird Man
Re: Not striking up
Post by The Bird Man » Sun Nov 02, 2014 6:09 pm
I thought the cam was timed to number four on these engines ?
Rhinoman
Re: Not striking up
Post by Rhinoman » Sun Nov 02, 2014 6:21 pm
The Bird Man wrote:I thought the cam was timed to number four on these engines ?
The procedure given in the FSM sets the valve timing at no4 TDC but it makes no difference as long as the ignition timing is properly set with no1 at TDC.
Rhinoman
Re: Not striking up
Post by Rhinoman » Sun Nov 02, 2014 6:25 pm
The Bird Man wrote:This is what I've done so far, number 4 piston at top dead center, crank sprocket timing mark lines up with the mark on the block. Both intake and exhaust valves are closed for that cylinder, the exhaust valve has been closed for a while and the intake valve has just come back up and is closed, cam sprocket timing marks also line up with the notch on the timing belt cover. This is the engine timing set up right isn't ? While it is like this the rotor arm was pointing to number four on the dizzy cap so I took the bolt out and took the distributor out and turned it to number one. This being all done, I don't see why it shouldn't start. I haven't missed anything have I ?
With both valves closed then no4 is at TDC on the compression stroke and the rotor arm should also point to no4. Which way are you turning the engine? I can't remember but did you do a compression test?
The Bird Man
Re: Not striking up
Post by The Bird Man » Sun Nov 02, 2014 6:27 pm
In that case, I've set everything up as it should be but still nothing, not even any back firing !! :S
The Bird Man
Re: Not striking up
Post by The Bird Man » Mon Nov 03, 2014 5:31 pm
In that case that's exactly the way it's set up now :D Have been turning the engine clockwise, and yeah compression test it one of the first things I did. 180 on 3 cylinders and 175 on another. Can't remember which on though I'm afraid.
Re: Not striking up
Post by ScottieJ » Mon Nov 03, 2014 5:47 pm
You are getting a good flow of fuel to the carb yeah?
Shame I'm not local otherwise I would be over to give you a hand.
The Bird Man
Re: Not striking up
Post by The Bird Man » Sat Nov 08, 2014 11:02 am
Yeah plenty, I found that out when I got a face full of the stuff when turning it over and forgot to put a jubilee clip on !! :lol: Cheers Scottie ;) God dam it, why can't I be nearer !
