justaddmud's kja build (code named MK5)
- ianedwards
- SCUK Addict
Re: justaddmud's kja build (code named MK5)
Tidy, because I haven't driven mine properly I don't know if it's worth doing while I'm rebuilding it all. Would be good if you could let me know. Cheers
Sent from my iPad using Forum Runner
- justaddmud
- Can I have a tow
what size tyres are you going to be running when finished?
i found mine with 235's pretty usable on and offroad without PAS, i just always wanted to do the conversion.
will let you know how it goes
- justaddmud
- Can I have a tow
found a couple of pics from an event i did last year, and if i could find my flashdrive, would have a bucket load more too
- ianedwards
- SCUK Addict
Um, I haven't looked to be honest. I'll look on Friday. You need to find those pics.
Cheers Ian
Cheers Ian
- ianedwards
- SCUK Addict
I had I look tonight while was doing my bearings and me tires are 235/75 R15 technic amazon.
Cheers Ian
Cheers Ian
- image-1027971352.png (902.13 KiB) Viewed 7237 times
- justaddmud
- Can I have a tow
Ahh same size as me then, well probably not this weekend, but next weekend, i will have all my EPAS setup and working so can let you know what it is like
wasn't bad before, only when steering stopped on the brakes made it hard to turn.
- ianedwards
- SCUK Addict
Tidy, hope it works well for you.
Cheers Ian
Cheers Ian
- justaddmud
- Can I have a tow
Hopefully it will, especially as I now have this on my desk
it is quite chunky, worried it may have too much offset, but we will see
also added the final peice to the exhaust, some bling
quite amazed that came out at all, was very dark,
will need a bit of fiddeling as that is only rested over the old pipe, but even so adds a distinctive touch
Looking good.
I need to get out on mine but cant strip the front clip in drizzle!
Make sure you let us know how the steering goes
Dan
Dan
- justaddmud
- Can I have a tow
the weather is such a pain isn't it, i have used a pop up gazeebo before now on the drive
first problem is going to be the mounting of the pump, and the fact that the eeejot that took the pump out cut the wire with only about 1cm left
and i have to get a 70 amp relay too, that is how much they pull aparently
