1991 Suzuki Samurai build
Re: 1991 Suzuki Samurai build
Post by ScottieJ » Tue Aug 27, 2013 9:37 pm
:doublethumbs:
Ah yes I forgot you ran that set up I just went back and looked at your pics. Would be the easiest option to keep a similar set up. Much easier than fitting them in with SPUA that's for sure.
gp7186
Post by gp7186 » Sun Sep 08, 2013 8:26 pm
Rear is now almost done just got to mount shocks and cut down a few pins
I then went to fit the rear prop but the uj's were a bit seized so I decided to modify and fit the toyota hilux prop I had in the garage. Firstly I made an adapter flange for end of the prop
Then I machined the prop to remove 145mm from the total length. I then welded it up and painted it.
I tried to keep everything perfectly in line so I will fit it and see if its out of balance if it is il get it balanced up
Post by turbo-tom » Sun Sep 08, 2013 9:33 pm
So casual! :lol:
looking really smart though!
gp7186
Post by gp7186 » Mon Sep 09, 2013 12:26 pm
:doublethumbs: Thanks tom
Fitted the hilux double carden prop this morning looks ok il just have to get it out for a run to see what it drives like
kiwizook
Post by kiwizook » Tue Sep 10, 2013 10:23 am
very nice work, my wagon up next?
Post by Jordi » Tue Sep 10, 2013 1:03 pm
Top rate work as always boss!
Only a little jealous.
gp7186
Post by gp7186 » Thu Sep 12, 2013 11:05 am
Thanks for the comments
Now to sort the shocks. I am going to mount the astra shocks that were on before then replace them with some decent shocks with longer travel. Firstly made an adapter bar for the rear from 8mm stainless plate
Then a pair of brackets to mount pin top shocks. I have made these to pivot using a brass thrust washer and again all made from stainless steel
Post by Jordi » Thu Sep 12, 2013 11:11 am
This sould have some pretty impressive articulation with the SPOA setup.
Post by turbo-tom » Thu Sep 12, 2013 11:24 am
Very nice so pressuming the shock bracket will swivell on the 8mm plate or am I missing something? Looks like it really has been thought through :hands:
gp7186
Post by gp7186 » Thu Sep 12, 2013 11:29 am
Jordi wrote:This sould have some pretty impressive articulation with the SPOA setup.
I can at least hope so they seem very flexible but I aint had it out the garage yet. Should have the bottom of the shocks mounted soon so il have to try it out of course.
