My Sj 410 build
Re: My Sj 410 build
Post by twiss » Tue Oct 29, 2013 10:55 am
For the starter motor you either need to find a skinny starter, or grind down the edge of a fat starter so it clears the oil passages sticking out of the engine
As for flex, you would probably get better flex if you put decent lift springs on and used some shorter shackles... You can see in the pic on the jack that the front passenger side spring it upside down and this will ruin them if they aren't already!!!
hensey212
Re: My Sj 410 build
Post by hensey212 » Tue Oct 29, 2013 11:01 am
twiss wrote:For the starter motor you either need to find a skinny starter, or grind down the edge of a fat starter so it clears the oil passages sticking out of the engine
Okay thanks for the info on the starter
The springs are flat so there pretty much fucked
Re: My Sj 410 build
Post by twiss » Tue Oct 29, 2013 11:19 am
FYI - Fat one (Mitsubishi)
Skinny One (Bosch)
Alternative Skinny One (Valeo)
You can also use these but it MUST be a D6RA13 (number 13 is stamped onto label after D6RA)
hensey212
Re: My Sj 410 build
Post by hensey212 » Tue Oct 29, 2013 11:43 am
twiss wrote:FYI - Fat one (Mitsubishi)
Skinny One (Bosch)
Thanks for that now the hunt begins for a starter
hensey212
Re: My Sj 410 build
Post by hensey212 » Mon Nov 18, 2013 2:33 pm
Well this is the end she's now gone to a new how where she's going to be built properly and used more then I ever did she might even go back on the road in some other form staying in touch with the new owner as I know he's started work on her as soon as I left got a new project everyones going to know what it is
kiwizook
Re: My Sj 410 build
Post by kiwizook » Tue Nov 19, 2013 4:26 am
what is it?
hensey212
Re: My Sj 410 build
Post by hensey212 » Tue Nov 19, 2013 8:36 am
kiwizook wrote:what is it?
Series 3 landrover
dazerede
Re: My Sj 410 build
Post by dazerede » Tue Nov 19, 2013 11:30 am
:jawdrop: WHY
4” calmini lift kit :)
kiwizook
Re: My Sj 410 build
Post by kiwizook » Tue Nov 19, 2013 6:26 pm
I regret even asking :roll:
you not been folowing the blandrover discussions on here?
