stevepsj413
Post by stevepsj413 » Thu Jun 19, 2014 7:52 pm
That's not the valve on top of the inlet manifold that I don't know the name of?
Your right, thats not the valve on the top of the inlet manifold, keep guessing!
Post by Tramp » Thu Jun 19, 2014 8:16 pm
4wd switch on the transfer box?
kiwizook
Post by kiwizook » Thu Jun 19, 2014 8:26 pm
it's definitely a switch, i don't think it's the 4wd one, as that has only one wire on it, and it looks like the pic has two, so I would think it's the switch on the gearbox, which I think is for the reverse light?
stevepsj413
Post by stevepsj413 » Thu Jun 19, 2014 11:03 pm
Thats it, its the reverse switch on the gearbox, your turn kiwizook!
kiwizook
Post by kiwizook » Fri Jun 20, 2014 7:33 am
pic is a little grainy, because it's dark outside, see if you can guess it though :D
Post by Tramp » Fri Jun 20, 2014 11:13 pm
Is it the filler point on the steering box?
kiwizook
Post by kiwizook » Sat Jun 21, 2014 7:08 am
good guess tramp, your turn!
Post by Tramp » Sat Jun 21, 2014 8:31 am
Go for it
Post by twiss » Sat Jun 21, 2014 10:07 am
Is it a steering column?
Edit: I know its a steering column... steering wheel end ;)
Post by Tramp » Sat Jun 21, 2014 11:36 am
twiss wrote:Is it a steering column?
Damn you! Yeah steering column!
Your turn twiss
