Page 73 of 85
Posted: Sat Jun 23, 2018 1:13 pm
Fuel filler cap welded on.
Sender unit bolted in. I used self drilling hex head screws from screwfix and was well impressed with them given i was screwing into 2mm steel.
Welded on the other end cap and made a start on tidying up the welding. Some parts welded beautifully, others not so great.
I am going with the presumption it will not be fuel tight but based on recommendation from a few mates iβm gonna definitely line it with liquid tank.
Itβs slow progress due to work and family commitments but it is progress.
Posted: Sat Jun 23, 2018 4:14 pm
4 120mm x 40mm steel plates. Clamped together, drilled and bolted together.
Some metal folding later.
Where the rears will bolts to the existing cross member.
Next step is to make two brackets to weld onto the chassis to support the rear of the tank.
Posted: Sat Jun 23, 2018 9:12 pm
by ROBBIE
Looking sweet
Posted: Sun Jun 24, 2018 11:47 pm
by donkeychomp
Looking great Jordi. Is the tank kinda the same size as an SJ one? If not your fuel gauge might be wrong...if it ever worked to begin with lol
Posted: Mon Jun 25, 2018 10:58 am
by ROBBIE
Looks the same shape size as that came with my LJ
Posted: Mon Jun 25, 2018 11:00 pm
donkeychomp wrote: βSun Jun 24, 2018 11:47 pm
Only ever worked between half and empty
It is a bigger tank but is pretty much the same depth so the standard sender unit will work fine it.
I honestly canβt remember its capactity. I sat for ages working it out too.
Bought a new sender from one of those indian ebay sellers too, hoping that work properly.
Just on researching the tank sealers now. So far the POR 15 seems most commonly used with generally good reviews.
Posted: Mon Jun 25, 2018 11:26 pm
by donkeychomp
Yeah POR is great stuff I've used it on bike tanks.
Posted: Tue Jun 26, 2018 12:55 pm
by timwilks13
Just drive at high revs all the time and you will use the fuel up before it has time to leak. Work smarter not harder.
Also grand job of the tank, will look good all finished and painted up!
Posted: Wed Jun 27, 2018 11:39 pm
by andyrew
Looks good dude.
Posted: Mon Jul 30, 2018 5:49 pm
More progress.
Brackets welded onto the tank and chassis brackets made and welded on.
