C'mon,
Another easy one,
Tell me where this is from, extra points for details on size & thread,
Another easy one,
- donkeychomp
A bolt with a washer...I suggest a new one is in order
- stevepsj413
Looks to me like a engine mount to chassis bolt, 14mm spanner, I think its a fine threaded m10, but im probably wrong.
Technically your incorrect anyway, it's a setscrew with washer and spring washer but I'd like to know where it's fromdonkeychomp wrote:A bolt with a washer...I suggest a new one is in order
It's not an engine mount to chassis bolt, but your right with the sizing, m10 fine (m10x1.25)stevepsj413 wrote:Looks to me like a engine mount to chassis bolt, 14mm spanner, I think its a fine threaded m10, but im probably wrong.
Stub axle bolt however I don't think they have the large washer?
Trying to think where else that size is used.
The little brace under the gearbox?
Neither, try again,dan_2k_uk wrote:Stub axle bolt however I don't think they have the large washer?
I seem to remember the radiator bracket bolts being large for no real reason.
I really recognise the little taper on the end but can't put my finger on the exact location.
That there would be a fuel tank/guard mounting bolt
"Technically your incorrect anyway, it's a setscrew with washer and spring washer but I'd like to know where it's from"
Bottom of a canal looking at it
Yet again.....ScottieJ wrote:That there would be a fuel tank/guard mounting bolt
