Scottie's Zuke. Blue
parrotveasey81
Re: Scottie's Zuke
Post by parrotveasey81 » Mon Nov 22, 2010 6:51 pm
8-) i take it you are not going to use missing links??
now pull your finger out as the good weather is on its way
Re: Scottie's Zuke
Post by ScottieJ » Mon Nov 22, 2010 9:58 pm
Cheers :smoke: nah no missing links here, I know a lot of people say its ok but I don't want any uncontrolled droop. I feel it will be more predictable and stable without missing links.
It should still get some pretty darn good flex though :smoke:
parrotveasey81
Re: Scottie's Zuke
Post by parrotveasey81 » Tue Nov 23, 2010 10:14 am
you may find you will have the same flex anyway due to the springs being inborad more than on a smmie 8-)
Re: Scottie's Zuke
Post by ScottieJ » Wed Dec 15, 2010 1:10 pm
slowly getting there on the front suspension, just need to tack it all up, test fit the front axle and cycle the suspension to check all the shackle angles, clearances etc.
These are the front mounts, they will be boxed in and welded on once finished.
parrotveasey81
Re: Scottie's Zuke
Post by parrotveasey81 » Wed Dec 15, 2010 8:56 pm
looking 8-) are you going to tie the front bumper into the front shackle mounts :?:
thats a mormal 4x4 work shop you have there,it is filled up with broken zuks and broken rovers :lol:
Re: Scottie's Zuke
Post by ScottieJ » Thu Dec 16, 2010 8:48 am
Yes parrot I'm going to build a new front bumper to work with the new mounts as I still want it removable.
Henry
Re: Scottie's Zuke
Post by Henry » Thu Dec 16, 2010 9:52 am
Looking good scott, i like it! :smokin:
Re: Scottie's Zuke
Post by ScottieJ » Thu Jan 13, 2011 1:42 pm
I was bored last night so i thought I'd change my dash set up :mrgreen:
it went from this
to
to
Re: Scottie's Zuke
Post by twiss » Thu Jan 13, 2011 1:49 pm
Looks good mate, make yourself some white dials and it will look bling :smokin:
Re: Scottie's Zuke
Post by ScottieJ » Thu Jan 13, 2011 1:55 pm
Thats a bit boy racer for me :lol: I'm going to slowly swap out the gauges for some more expensive/accurate ones that have black faces, I fancy some nice Autometer ones :mrgreen: these ones are so bright that i'm going to wire in a switch to turn the lights off a night so I can see the road better :lol:
