SU Carbs
Re: SU Carbs
Post by Jordi » Thu Dec 06, 2012 8:50 pm
As you look at the carb if it is the same as mine the bottom pipe that sticks out at 90* is fuel in. The top two sticking out at 45* are fuel over flow i think. The left one. And the larger right one is a breather.
I'll be corrected if i'm wrong but thats how mine is plumbed up.
At the moment i've got the breather and over flow capped off. Runs ok.
Re: SU Carbs
Post by ScottieJ » Thu Dec 06, 2012 9:45 pm
Bdl needle and red spring for a 1300 as written on page 1. Ill message Twiss and ask him to add the photos again!
Jordi have you got the fuel overflow blocked off in that pic? (Middle pipe)
Re: SU Carbs
Post by Jordi » Thu Dec 06, 2012 9:50 pm
Yup. Blocked off. Did have a pipe running down the engine bay. I should really fit it as a propper fuel return to the tank.
What have you done with yours?
Re: SU Carbs
Post by ScottieJ » Thu Dec 06, 2012 10:00 pm
Mines just left open, need to put some pipe on it really. With SUs if fuel comes out the overflow it normally means there's something wrong so you'll find that it will be very rare for fuel to actually come out of it, no point plumbing it back to the tank in my opinion.
Re: SU Carbs
Post by Jordi » Thu Dec 06, 2012 10:11 pm
Thats why it's blocked off. My main concern leaving it open was anything going into it. It runs fine so i haven't wanted to tamper with anything.
SJ Greg
Re: SU Carbs
Post by SJ Greg » Fri Dec 07, 2012 6:52 pm
thanks guys now have the correct needle and spring on order
screeminsj
Re: SU Carbs
Post by screeminsj » Sun Feb 03, 2013 12:34 pm
Hi guys why do you guys prefer the hif44 instead fo the hs 13/4 su? I have an hs carb but the needle has been robbed, on the black jet is the number 5, does anyone have a clue to wot jet i need?thanks for any advise steve
Re: SU Carbs
Post by ScottieJ » Tue Feb 05, 2013 1:23 pm
I have a feeling the HS SU carbs aren't as good with extreme angles as the HIF SU carbs. most people do run the HIF44s but you could always try the HS carb and see what it's like? I'm afraid that I haven't got a clue about the Jets and needles on HS carbs either.
fatdaz
Re: SU Carbs
Post by fatdaz » Wed Mar 20, 2013 9:18 am
my freind has found a brand new su carb in his garage from his mini days. now the last engine in his mini was a 1275 so im hoping it will be the right one for my 413...?
the only codes on it are
zx1094
rg611
aud9208
auc8103
aud2859
any ideas?
2 samurais. 1 vit and now a vit commercial :)
Re: SU Carbs
Post by Jordi » Wed Mar 20, 2013 10:50 am
Measure the bore. Should be 44mm.
Stick a photo up if you can too.
