Page 9 of 9
Re: Red neck lift kit lads!
Posted: Thu May 16, 2013 3:46 pm
Yeah Im not lifting mine up any more than it is... when going through deep ruts i have bashed the bottom, but its worth it for the stability!
Posted: Thu May 16, 2013 4:13 pm
Raising my transfer box 2" was one if the best things I did I think, not only does it give you 2" more ground clearance underneath but it also raises the props so they are out of the way, I've grounded out in my front prop a few times
Here's a good example of me resting on my front propshaft before the tcase lift
- image.jpg (55.15 KiB) Viewed 3337 times
Posted: Thu May 16, 2013 4:22 pm
See i only really ground out on the diffs... ive only hit the t-case when driving up a 45* concrete slope and up onto flat ground! I suppose theres still plenty of time left to smack it about some more
Posted: Fri Jun 07, 2013 12:02 am
by turbo-tom
It dont stop there boys you can get eco friend lift block saddles aswell chop to your own height as and when required and glue them back together!
Posted: Fri Jun 07, 2013 8:43 am
by ROBBIE
It dosent need breaks either
Posted: Fri Jun 07, 2013 9:50 am
turbo-tom wrote:It dont stop there boys you can get eco friend lift block saddles aswell chop to your own height as and when required and glue them back together!
He could have at least put the u bolts the right way.
