Kiwizook's resto
Re: Kiwizook's resto
Post by turbo-tom » Sat Jun 15, 2013 1:30 pm
Looking good Buddy. I like them wheels!
kiwizook
Post by kiwizook » Wed Jul 03, 2013 10:17 am
so glad I took the head of my engine. it was filthy, two head bolts were tight as a tiger, most water channels were blocked, and a lot of the oil channels are blocked too. here's some pics of the mess inside the engine
and the head all blocked up
the beauty head gasket
blocked water chanels
the water channels are blocked in places with a hard salt like substance. anyone know what it is, and how to clean it out?
Post by Jordi » Wed Jul 03, 2013 10:44 am
Wire brush. Crystalised anti freeze.
If you actually need to rinse through the channels and cant get at them with a wire brush. Pressure washer. The crystals should dissolve and rinse away.
kiwizook
Post by kiwizook » Wed Jul 03, 2013 10:57 am
oh, and anyone know why two valves are brown, and six black? the brown valves also had the brown on the corresponding sparkplugs
thanks jordi, will try that. am also getting a quote tomorow on getting it cleaned at the engine rebuilders in town, just pulling it through their bath I think
Post by Jordi » Wed Jul 03, 2013 11:06 am
If its had a dodgy head or hasn't been burning properly it affects the valves.
I can't remember which colour means what but it's definately a sign it was a poorly engine.
Post by turbo-tom » Wed Jul 03, 2013 11:13 am
There we go! Bet your glad you wipped the head off now!
Ladaman
Post by Ladaman » Wed Jul 03, 2013 12:15 pm
I'd look at getting some new core plugs for the block also. Not just because they are probably knackered (looking at the crud in the engine), but I think you will find LOTS of corrosion around the water jacket at the bottom of the block.
Worth doing now for a few $ rather than lose cooling capacity, or springing a leak later.
Boyes
Post by Boyes » Wed Jul 03, 2013 12:17 pm
Brown spark plugs = Running lean, Black sooty spark plugs = Running rich.
Post by ScottieJ » Wed Jul 03, 2013 1:13 pm
Boyes wrote:Brown spark plugs = Running lean, Black sooty spark plugs = Running rich.
Isn't light grey/brown the correct mixture
kiwizook
Post by kiwizook » Wed Jul 03, 2013 8:29 pm
hmm, I think it might have been burning a little oil, and the plugs were worn out too.
Darell, do you have a diagram to show where the core plugs are in the engine? will still have to take oil sump off, and clean all that. I've never done anything like this before, so it's a good experience and learning curve for me, really enjoying it now :D
