Choke cable
Choke cable
Alright folks, having a spot of bother. Regarding the choke cable, where can I get a new one ? Also the nob that you pull the choke out, how do I get it off ? Cheers
- Ladaman
- Suzuki Guru
Re: Choke cable
Thinking back to the "old days" with manual chokes. I recall the knob was part of the inner cable, so I don't believe they come off.
Can you make this fit? If not there seem to be a few on eBay.
Click Here for Ebay Listing
Item number 360827652291
Re: Choke cable
Loads of universal cables on ebay. Think I paid about £5.
Re: Choke cable
I got a universal one from my local motor factor for a fiver
Re: Choke cable
Had a scan through Ebay at the universal ones, none of them have the little button at the end, Also looking at my old one it had a bolt and two nuts as part of the cable it self to hold back the choke some what and they clamp on to a metal bracket. I'm confused as I can't seem to find any choke cables like this one
Re: Choke cable
Hopefully this pic will clarify what I'm after
I rang up my local Suzuki dealership up this morning, just for a giggle, where I got through to the parts department, they quoted me 30 nicker for a choke cable all the way from Germany !!
I was like, on your bike pal
There must be a cheaper alternative.
- Choke cable.JPG (6.68 MiB) Viewed 6472 times
- timwilks13
- SCUK Website Padawan
Re: Choke cable
I bought mine from a local motor factors, about £6 and just fabbed it to make it fit, seems to be what most people do mate.
Re: Choke cable
Right, been looking at how to fab one, I've come up with this. Don't see why this shouldn't work, it will be pretty much the same apart from the bend at the end where the adjuster is.
http://www.ebay.co.uk/itm/UNIVERSAL-LOC ... 3f33601579
http://www.ebay.co.uk/itm/Motorcycle-Sc ... 460dca7edc
http://www.ebay.co.uk/itm/Cable-Adjuste ... 2c7458982c
Re: Choke cable
looks like it should work
Is it possible to use your old cable 90 degree bend and adjuster, or is it crimped on.
