2007 Grand Vitara 1.9 DDIS not starting
CAYENNE12
Post by CAYENNE12 » Wed Mar 19, 2014 10:27 am
Hi all
I just got myself a 2007 Grand Vitara - the engine warning light was on but it started and ran ok until yesterday - plugged in Launch to investigate the warning light and reset fault codes, re-programmed all injectors but the injector warning/immobiliser light is now flashing and there's another lot of fault codes so it's all show no go - turns over but won't start?
DF226 Damper flap control cricuit, short circuit
DF226 Damper flap control circuit, diagnosis outside domain
PO638 Throttle Actuator Control Range/Performance Bank 1
Have I dropped on a lemon or just having a bad day? Any advice would be appriciated.
Probably worth a mention - it has only recently had new injectors, glow plugs and turbo fitted
Thanks in advance
