adaptor plate
- timwilks13
- SCUK Website Padawan
adaptor plate
Thinking of doing away with my home made j bolts and putting an adaptor plate between the engine and gearbox, however with the extra thickness will the engine and gear box still fit into the same mounts, as the entire engine gearbox length will be 10mm ish longer?
Re: adaptor plate
They will probably stretch so suit. Why bother now its all sorted though?
- timwilks13
Re: adaptor plate
Isn't it meant to be the better way of doing it? If it makes no difference either way I'll leave it, but had done that as a temporary measure.
Re: adaptor plate
Mines about 5-6mm thick and it DID bolt up ok to the standard mount originally
Re: adaptor plate
I wouldn't worry if it works. Me and Trotter don't have adapter plates and no problems.
Re: adaptor plate
Yeah I didn't use one for years... the only reason I'm using one now is cos it came with my 16v engine
Re: adaptor plate
I'm sure that my adapter plate is only about 3mm thick.
