Making my Suzuki sj 410 to electronic distributer
- dazerede
I have had enough of the points in the dizzy have to adjust them all the time
I have a 1.6 8v distributer and a coil is it a straight swap chears
4” calmini lift kit
4” calmini lift kit
Re: Making my Suzuki sj 410 to electronic distributer
I think a 1.3 dizzy goes straight on. Not too sure about the 1.6.
- dazerede
Oh ok what is the diffrence between 1.3 and 1.6 dizzy then
4” calmini lift kit
4” calmini lift kit
I dunno
- dizzies.png (325.45 KiB) Viewed 5008 times
Mine had different wiring between the two so presumed they would be different in some other way too.
The drive gear on the bottom of the dizzy is different I think.
That's why if using a 1.6 dizzy on a 1.3 you have to swap the housing on the back of head and vice versa.
BUT there might be a chance that the 1.6 you have has a 1.3 dizzy as people often swap it over
I know a 1.3 dizzy slips straight in, the 1.6 drive gear might not quite mesh right.
For wiring follow the 1.6 into a 410 guide in the electrical section.
Also remember that there's no vac take off for the vacuum advance on the dizzy so you can't run it.
Ive got a couple of dizzys, one has a longer shaft under the drive gear and the other has no shaft. Both came out of 1.6 vits
Im using a dizzy with a 1.3 gear in my 16v... can't be that different
Should have finished this, only one will fit in a 1.3ROBBIE wrote:Ive got a couple of dizzys, one has a longer shaft under the drive gear and the other has no shaft. Both came out of 1.6 vits
yes with the correct housing for the dizzy and an adapter, it's not the teeth that are different.twiss wrote:Im using a dizzy with a 1.3 gear in my 16v... can't be that different
