LOW GEARS
jim tylee
LOW GEARS
Post by jim tylee » Wed Apr 16, 2014 10:08 am
Can i select 4 wheel drive and use my sj413 with the front wheels unlocked without doing any damage.....hopefully no wind-up on the transmission system.....always wondered about this
thanks Jim
Relaxing
Relaxing
jim with big cigar.jpg (3.45 KiB) Viewed 6460 times
Ladaman
Re: LOW GEARS
Post by Ladaman » Wed Apr 16, 2014 10:39 am
I would say yes, but why would you want to do it?
jim tylee
Re: LOW GEARS
Post by jim tylee » Wed Apr 16, 2014 10:44 am
Just thought i would try it if it does not cause any damage...very steep hill nearby
Jim
Re: LOW GEARS
Post by Edweird » Wed Apr 16, 2014 11:14 am
Ah, you mean 4 wheel drive low ratio. I have gone into 4-low with the front hubs unlocked a handful of times, but only for pulling the trailer up the ramp on the back drive as it's a 60% grade and pretty narrow so I want more control. I wouldn't do it for any real distance (more than, say, two dozen yards); plus, the SJ is pretty low geared anyway. I've found that even in the likes of the Lincolnshire Wolds or the Yorkshire Moors the most I've ever really had to do is not go into 4th and be quick about my gear changes.
Boyes
Re: LOW GEARS
Post by Boyes » Wed Apr 16, 2014 11:42 am
You can mod the box/stick to get 2wd low I beleive there's a guide on here...
http://www.suzukiclubuk.co.uk/diy/16-tr ... wd-low-mod
:D
Re: LOW GEARS
Post by twiss » Wed Apr 16, 2014 5:50 pm
Ive heard that you can damage the hubs by driving them when they are unlocked
Re: LOW GEARS
Post by Edweird » Wed Apr 16, 2014 6:23 pm
I have heard this too but not encountered any problems. I figured I can probably get away with doing a whole ten/fifteen yards in a straight line at a maximum speed of 2 miles an hour.
Wouldn't do anything more than that though. The only reason I do is the SJ drops down the back drive easy as pie whereas the Lawn Mower only has about an inch of leeway; the Discovery is the one that actually tows the trailer, I just use the SJ to maneuver it.
dazerede
Re: LOW GEARS
Post by dazerede » Thu Apr 17, 2014 8:31 am
Ye I was thinking this question back along when I went for a dip in the river and the back wheels was just spinning and my hubs was in free and I only had trainers on so I decided to put it in 4L with hubs in free and I managed to get out lol
4” calmini lift kit :)
Re: LOW GEARS
Post by ROBBIE » Thu Apr 17, 2014 9:13 am
dazerede wrote:Ye I was thinking this question back along when I went for a dip in the river and the back wheels was just spinning and my hubs was in free and I only had trainers on so I decided to put it in 4L with hubs in free and I managed to get out lol
I always did rivers in 4 with hubs locked, can get a bit scary when the back end floats
Re: LOW GEARS
Post by twiss » Thu Apr 17, 2014 10:58 am
If you need to tow something heavy a reasonable distance in low ratio I would maybe consider disconnecting the front prop
