I have a chance of some Running Boards for my 54 GV
Nice & cheap but no brackets supplied.
Am i able to locate the mounting brackets anywhere or is it impossible and this is why the running boards are cheap ?
Please advise,thanks.
I dont have enough posts at the moment so i cant post an add in the wanted section.
Grand Vitara Running Boards 5dr
Grand Vitara,54 plate,2000cc,Manual,5 Door,Air Con,4WD.
- muddymesser
Re: Grand Vitara Running Boards 5dr
you should be able to buy them depending on the type of side step etc but looking on http://www.direct4x4.co.uk/suzuki-grand ... -side-bars they dont look like they would be too hard to make the brackets
- RickUK
- Can I have a tow
As a general rule the steps will last for ever as they are usually made out of stainless or alloy and the mounting brackets are steel,so i would think that the brackets have rotted away over time and hence this is why they had been such a bargain price.I had the same thing happen on my Trooper but was able to make a set of brackets up on the drivers side and had them on my truck for about 15 years.
Hope you do find all the fittings for them,but not sure who you could buy them from unless of course they have some makers mark on them.
Deceased.
Current wheels.
Current wheels.
Thanks for the info.
If i buy them would anybody make me the brackets ?
I will pay obviously.
