suzuki vitara engine problem
neil atkins
Post by neil atkins » Sun Apr 27, 2014 10:16 am
Hi there my vitara has a 1992 single point injection engine in it.i have removed the injection system it was faulty and fitted a hif44 carb with a BFM needle and a low pressure pump for fuel the ECU is still running the ignition side.the problem i have is the engine will tick over but when revved up it has a flat spot about 1500-2000 RPM after that it is ok if the ECU is causing the problem is there someone i can take the ECU to Thanks Neil
Re: suzuki vitara engine problem
Post by twiss » Sun Apr 27, 2014 10:34 am
I'd imagine the ECU isn't advancing the ignition timing properly... this would give a flat spot...
Rhinoman is the dude to talk to about anything ECU related but personally if you are running a carb I would put a proper carb distributor on it
Got a few in a box if you're anywhere near me sure I can spare one lol
neil atkins
Post by neil atkins » Sun Apr 27, 2014 12:05 pm
for SCUK Computer Wizad thanks for the info i will get one and try that Thank Neil :thumbup:
Post by Jordi » Sun Apr 27, 2014 1:27 pm
As i never had the ECU when I fitted the SPI engine in my Samurai I fitted the 1.3 dizzy and coil. Works spot on.
neil atkins
Post by neil atkins » Mon Apr 28, 2014 8:40 pm
Hi there can someone tell me how to tell the difference between an injection distributor and a carberetor distributor on a suzuki vitara Thanks Neil
Post by Darrell » Mon Apr 28, 2014 10:35 pm
Done this..........
Vitara distributors.jpg (276.63 KiB) Viewed 6085 times
neil atkins
Post by neil atkins » Tue Apr 29, 2014 8:21 am
Thank for showing me the difference.Thanks Neil :doublethumbs:
