tyre size
vit4x4
tyre size
Post by vit4x4 » Tue May 06, 2014 4:32 pm
hi i have just bought a suzuki blitz and was wondering what are the best size tyres i can fit, for off roading and not ruining the gearing thank you in advance michael
Rhinoman
Re: tyre size
Post by Rhinoman » Tue May 06, 2014 6:34 pm
That will depend on what engine you have and what the current gearing is.
vit4x4
Re: tyre size
Post by vit4x4 » Tue May 06, 2014 8:00 pm
1300 and standard gearing thank you rhinoman
Re: tyre size
Post by Jordi » Tue May 06, 2014 8:04 pm
Run on 215s and 235s on my SJs with standard gearing and runs fine. Had 31s on my Samurai on standard gearing and they were too big, killed it pulling away, no top end.
Found 31s ideal with a rock lobster, but a 410 tbox is fine too.
Rhinoman
Re: tyre size
Post by Rhinoman » Tue May 06, 2014 8:07 pm
On mine I found that there was less clearance to the footwells than on a stock SJ, personally I wouldn't want to go above 215/80s on stock gearing. If you want to go bigger then the alternative is to gear down and move the axle forward.
vit4x4
Re: tyre size
Post by vit4x4 » Tue May 06, 2014 8:34 pm
thank you jordi & rinoman 215 80 15 it is then
