wiring info
wiring info
Hi there my vitara 1992 was injection now its carberetor can someone tell me how to wire up the distributor from a carberetor model ignition module and coil in a word HELP Thanks Neil
Re: wiring info
I would just unplug the old main relay as it's not supplying anything now and connect the b/w to ignition coil as before.
- vit ign.jpg (112.31 KiB) Viewed 6269 times
Re: wiring info
Thanks darrell I have looked allmost every were I was just about to give in. It's been a long task for me to convert from injection to carberetor I hope I can get it sorted now Thanks Neil
- Ladaman
- Suzuki Guru
Re: wiring info
Why would you want to do that?neil atkins wrote:It's been a long task for me to convert from injection to carberetor I hope I can get it sorted now Thanks Neil
Re: wiring info
Hi there I did this because the ecu nackerd on me and could not get one
Re: wiring info
Hi there thanks for the info on the wireing it works fine but lost mt rev counter what do I need to get it working Thanks Neil
Re: wiring info
Hopefully there is still the old brown with white tracer coming from the main wiring loom that went to the old coil. It came from the noise suppressor which I hope is still there, if so connect this to the coil negative terminal and see if that works.
- vit inj ign.png (73.94 KiB) Viewed 6208 times
Re: wiring info
Thanks again Darrell put the wire on and the rev counter works Thanks Neil
Re: wiring info
neil atkins wrote:Hi there I did this because the ecu nackerd on me and could not get one
You could have spoken to me I do repairs and have exchange units.
