Window wiper motor switch
Gaz6oy
Post by Gaz6oy » Fri May 23, 2014 7:48 pm
Hi all i have a suzuki sj and have no life to the window wiper motor whats the best way of wiring it upto a flick switch as the washer has already been done onto a two way switch so wanted to wire the motor to the other terminal i have the wiring diagram for the existing switch but cant make heads or tails of what i need to connect to make them work
Re: Window wiper motor switch
Post by Darrell » Fri May 23, 2014 10:21 pm
It's not easy to use a standard switch to operate the wipers, well not if you want the blades to self park when you switch them off.
If the switch/stalk is knackered I would try and get a used one from somebody on here.
Gaz6oy
Post by Gaz6oy » Sat May 24, 2014 12:17 pm
Im not to fussed where they park as its mainly used off road but without wipers she cant go anywhere as we all no the english weather aint the best lol
Post by Darrell » Sat May 24, 2014 12:56 pm
In that case this would do.
If your switch is already a on/off/on and one side is doing the washers just connect the other to either high or low.
For the price of a switch I would go for both speeds :thumbup:
Hope this is what you wanted ;)
Wipers. No park. No intermittant..png (139.79 KiB) Viewed 3588 times
