Cooling Issues
Posted: Fri May 30, 2014 6:08 pm
Write chaps answers please.
Samurai 413 engine all standard except for a webber carb, the temperature runs in the red after 10 minutes, I`ve replaced thermostat sender unit twice, two different makes just in case, thermostat changed, the first one was bust but I also tried the new one in the kettle to double check that it opened. The water pump runs quiet and is not leaking and no play on pulley. When it gets warm the top hose after the thermostat is hot, both pipes in and out of heater matrix are hot, bottom pipe from radiator is cold, if it runs with the radiator cap off I cannot see any flow, the radiator was new 7 years ago and the vehicle does 1000miles/yr and the coolant has been changed too.
On past experience I would look towards the water pump but there is no leaking or clatter and banging coming from it, at the moment I`m not fired upt to strip it down that far and thought Id ask you guys first.........
