Sami gearbox advice please
djc
Post by djc » Mon Jun 16, 2014 10:10 pm
Hi, got a '91 with 63k on it. Engine good, sweet etc (so far) but gearbox noisy. I get a whine in all gears but that sounds fine (a happy-gear sound) and from memory my 410 years ago did the same. The BAD bit is if I press accellerator harder (up hill say) it goes into a graunchy mashing sound (not happy) - most notable 3rd and 4th (5 spd).
I know this Sami has spent almost all it's life on road so 2wd- hence best guess is main box.
Any ideas on severity of problem please, can I get this one rebuilt, or exchange a refurb??
I'd be well up for another box but where from, how to get a good 'un.
thanks, Douglas
Douglas
Re: Sami gearbox advice please
Post by Jordi » Mon Jun 16, 2014 10:30 pm
Only way to guarantee a good box to to refurb one.
Approx £300, fairly sure you can buy all the bits to do it yourself if you're brave enough.
Ladaman
Post by Ladaman » Mon Jun 16, 2014 11:19 pm
I've still got my old 5 speed that was in mine before the engine change if you're interested in changing it.
It was okay as far as I remember.
Whereabouts are you?
Post by dan_2k_uk » Tue Jun 17, 2014 8:20 am
I would at least do a little diagnosis To check which box it is before you go to the expense and effort of fitting a new gear box.
djc
Post by djc » Wed Jun 18, 2014 6:50 am
Hi Dan, agreed - I'm sure the bad noise is coming from that area but could be the Tbox. As the noise is under load when moving, how do I get to find out which, any ideas? I plan to do an oil change on both boxes anyway just as a precaution,
Douglas
Post by ROBBIE » Wed Jun 18, 2014 9:28 am
Stick the t/box in neutral and gently run through the gears
djc
Post by djc » Wed Jun 18, 2014 9:56 am
Thanks Robbie, will do.
Ladaman - interested. I'm in Kent but my dad is Yorkshire so I go up every so often. Can't pm you as a newbie but pse txt me 07734 103709. Thanks, Douglas
Douglas
