standard or su carb needed!!!!
jameswilts
Post by jameswilts » Tue Sep 01, 2009 1:19 pm
my friend has a sammi and is in desprit need of a new carb.
when he goes round corners the engine stalls and on tick over
the engine is reving realy low. he has cleaned everything and cheacked for
leaks. we are no master machanic's so any help would be greatly appriciated.
thanks
Please help me find a new zook!!
Re: standard or su carb needed!!!!
Post by ScottieJ » Tue Sep 01, 2009 5:34 pm
i think i have one but the chokes a bit fooked! perhaps if his has a good choke you could swap it over?
Scott
jameswilts
Post by jameswilts » Tue Sep 01, 2009 6:37 pm
think he will try anything mate!! at the mo his has a auto choke,
ant news on leaf springs? thanks
Henry
Post by Henry » Tue Sep 01, 2009 7:34 pm
Whats it for? I have a 410 one.
liljitjit
Post by liljitjit » Tue Sep 01, 2009 9:27 pm
hi if you have a look on difflock.com under suzuki they have some exellent info on both standard aisin carbs (how to strip and service) and on conversion to su . su is the way but you will need to fabricate a manifold adaptor or buy one from ebay as the stndard carb is a down draft and an su is side draft. I have had bothon my sammy and the su is best but i have just sourced a newer standard carb to fit whilst i remake my su adapter.!!! good luck. Oh just rememberd if you can find one a charade 1300 carb does fit with a little tweeking.
rich
[/color]before you laugh at mine , take a look at your own![/color]
jameswilts
Post by jameswilts » Wed Sep 02, 2009 5:42 pm
its a sammy 1.3 petrol i believe :|
Post by ScottieJ » Thu Sep 03, 2009 9:07 am
found the carb matey! will pop over to you this weekend!
