check your prop...
- firemansam
check your prop...
if you have a lift and no spacers or driveshaft modifications, then its probably worth having a gander at your shafts...
i wondered what the severe vibration i had under acceleration was.
turns out the rear driveshaft had disintergrated and was hanging on by a thread.
My lift (3.5") articulates too much for the driveshaft, and causes rubbing. And over a year has worn away the U-joint ears.
cost me £100 to have the shaft repaired, luckily they had the part in stock on friday, as i was due to go wheelin saturday and today
purrs like a kitten now
have a look at yours!
Re: check your prop...
where did you get it repaired? i trashed my rear prop end of last year and have been running around on a spare one a mate had. i'm gonna ask suzuki if they have any new ones led about now this has reminded me.
if in doubt, FLAT OUT!
- firemansam
driveshaft services limited, near bridgend in south wales
not cheap, they replaced the flange, yoke and U-joint, good job too...
01656741999 is their phone number
nice one cheers
- urbanzook
- Winching along now
LOOK ON EBAY 49.99 2 REFURB YOURS YOU SEND YOURS OFF AN THEY DO THE DO. SENDING IT BACK FREE. IV JUST LOOKED FOR THE ADD BUT IS NOT THERE WILL POST IT WHEN ITS BACK.
i saw that thought it was only to replace the uj's though
- urbanzook
you may be right idont no
