Suzuki samurai transfer case mount
- TomBod08
So the original one snapped in half. I bought another one on the cheap and that snapped after less than a mile. I want one of decent quality, and I'm not too bothered about spending too much on of it works well. I found one in America but it's too expensive to ship over.
http://www.lowrangeoffroad.com/oem-tran ... ounts.html
Anyone know where I can find the same one or a better quality one from?
One life. Live it....With a Suzuki
Re: Suzuki samurai transfer case mount
I've bolted mine through and used some spare poly bushes I between.
Works great, but you have to use but washers otherwise then can rip the bolts through
- TomBod08
Don't have any spare poly bushes , I know what you mean though, sounds like it would hold.
I bought these from KAP Suzuki http://www.kapsuzuki4x4.co.uk/suzuki/samurai.php not cheap but I've had no issues
Llama 4x4 do them too
The Twiss way worked for me
As Jordi says, Dave at Llama 4x4 does a proper version of what I've made
At least then if the bushes go the transfer box still can't escape haha
- llama4x4 tranfer case mounts 2.jpg (75.51 KiB) Viewed 8279 times
- llama4x4 tranfer case mounts.jpg (94.31 KiB) Viewed 8279 times
Darrell saves the day again!
It didn't exactly cost me £30 to make mine but if you're going to buy it I'd shell out the extra £8.40
- TomBod08
Nice, think I'll go for the ones at Llama 4x4. Cheers guys
