oil leak on front drivers side hub? please help
Hi guys ive got grease/oil leaking out what I think is the front hub? Can someone tell me exactly what it is so I know how to fix it properly? Jus wana know the part so I can source a replacement. Its all completly standard. Cheers
- 20140802_174152.jpg (827.55 KiB) Viewed 6752 times
Re: oil leak on front drivers side hub? please help
Check for play, that's usually a sign of worn kingpin bearings.
Could be a combination of things causing it. There is an inner oil seal that's most likely gone. Possibly caused by worn wheel or king pin bearings.
You can get a full set of everything off eBay. Item no.400645807234
Hey tom,
I normally just get mine from Worthing suzuki (in findon) they aren't that expensive
I've recently replaced mine so I will find the packaging for it
I can give you a hand if you want. I've rebuilt front axles quite a few time now
Hoping to get mine out of the garage this week (before muddymesser
I can also probably tell you which bearing has gone and caused it...
Cheers guys! Ok twiss ill get back to you about that! Are they pretty easy to change?
Yeah pretty easy to be honest
You can rebuild the whole hub with basic hand tools
Ok cool, ive just found a front wheel bearing kit for 32 quid, does that sound about right?
The bearing might be ok probably best to check it first
I would get the seal, we can have a look at it to see what's wrong with it
You can get the wheel bearing and kingpin kits pretty cheap from Clifford's in hove
