suspension lift
fossil
suspension lift
Post by fossil » Mon Aug 11, 2014 7:01 pm
Hi all,
need some advice here, i have done a 2" body lift and a 3" suspension lift on my Vitara
i have sorted the fuel hose,brake lines, wire loom etc and also removed the anti roll bar for better articulation, looking at the from drive shafts the angle going down to the front hub is quiet acute which gave some cause for concern,however onwards and upwards i went out to play
the first set of ruts i came up against ripped the body of the passenger side CV joint open like a tin of baked beans!! the whole joint was completely destroyed
am i missing something here,or is it just very bad luck on the first trip out!!
many thanks upfront
Phil
Re: suspension lift
Post by Jordi » Mon Aug 11, 2014 7:11 pm
Diff drop bracket fitted?
Re: suspension lift
Post by Jordi » Mon Aug 11, 2014 7:13 pm
fossil
Re: suspension lift
Post by fossil » Mon Aug 11, 2014 7:24 pm
hi
thanks for responding real quick,diff drop bracket?
where must i go for such a thing, certainly dropping the diff would decrease the acute angle
thanks
phil
Re: suspension lift
Post by Jordi » Mon Aug 11, 2014 7:33 pm
Follow the vits for bits link. Sounds like that's what you're missing. Has a brief description of how it works on their website.
fossil
Re: suspension lift
Post by fossil » Mon Aug 11, 2014 7:45 pm
hi
me again thanks can see them now, another question im afraid they talk of a third poly bush do i get that also?
thanks again for your time
phil
Re: suspension lift
Post by Jordi » Mon Aug 11, 2014 7:51 pm
No idea about the poly bush, I actually drive an SJ. Sure some vitara owners will be along soon with more info, always worth a phone call to vits for bits and explain to them what you already have fitted and see what the recommend.
Jimnybits also do them, had a few bits and pieces from them. All seems spot on.
fossil
Re: suspension lift
Post by fossil » Mon Aug 11, 2014 8:09 pm
hi
thanks again you have been very helpful, i have read that the drive shafts on the grand vitara also fit just the standard vit, mines a 1998 three door, can you advise on the best place to get a replacement drive shaft
phil
Re: suspension lift
Post by Jordi » Mon Aug 11, 2014 8:26 pm
There might be someone breaking a vitara on the forum, other than that it's ring around local breakers yards. Don't think you'd get one from a motor factors and Suzuki won't be cheap.
Re: suspension lift
Post by twiss » Mon Aug 11, 2014 8:28 pm
The 3rd member bush is also on the bits 4 bits web shop
http://www.bits4vits.co.uk/store/vitara ... d_496.html
