need abit of help
lesward
need abit of help
Post by lesward » Sat Aug 23, 2014 2:20 pm
my stalks flop around like crazy in the steering column casings am i missing something they secure too? pic of casings below show some holes that i have nothing for the 3 in triangle formation
2014-08-20 14.36.37.jpg (2.63 MiB) Viewed 8499 times
2014-08-20 13.02.18.jpg (2.42 MiB) Viewed 8499 times
Re: need abit of help
Post by dan_2k_uk » Sat Aug 23, 2014 5:36 pm
I've no idea but to help someone who may are they round or square stalks?
lesward
Post by lesward » Sun Aug 24, 2014 5:19 pm
round stalks bud
Post by Darrell » Mon Aug 25, 2014 12:07 am
Not sure about the plastic casing but I think 4 screws hold the switch assembly to the steering column.
Suzuki SJ switches.jpg (94.52 KiB) Viewed 8449 times
lesward
Post by lesward » Mon Aug 25, 2014 6:06 pm
i must be missing something off column then to screw it too anyone have a pic of what stalks screw too?
Post by Darrell » Mon Aug 25, 2014 7:01 pm
Now I'm a bit confused because this pic shows screws top and bottom and the column bracket looks correct for this.. :er: :er:
lesward
Post by lesward » Thu Aug 28, 2014 2:42 pm
none of those brackets on my column
lesward
Post by lesward » Thu Aug 28, 2014 2:44 pm
previous owner must of bust them off when bust ignition barrell off damn
djc
Post by djc » Sat Aug 30, 2014 7:43 am
Doesn't this depend on your sj year/model etc? Just had to get inside mine due to lighting fault - the covers (you show) are not the mount for switches on mine they just cover all the gubbins, and are fixed together with 3 small cross-head bolts (about M4 maybe, guess) into the 3 holes nearer centre of moulding, and then 2 long self-tappers into holes at front. The first 3 fix lower moulding to metal on column but do not fix the switches. On mine (a '91, spaniard) the switch blocks are seperate (left and right) and each is fixed to the bracket on column using 2 more cross-head bolts (about M4 again, guess) - these go through the plate on column into blind threaded holes in switch block.
Sounds to me you are missing a few screws but yours may be the different version anyway - all switching on one lump like Darrell's pic??
p.s. if yours sounds like mine (i.e. seperate switch blocks left and right) I can do a pic as it's still in bits
Douglas
lesward
Post by lesward » Mon Sep 01, 2014 3:42 pm
djc wrote:Doesn't this depend on your sj year/model etc? Just had to get inside mine due to lighting fault - the covers (you show) are not the mount for switches on mine they just cover all the gubbins, and are fixed together with 3 small cross-head bolts (about M4 maybe, guess) into the 3 holes nearer centre of moulding, and then 2 long self-tappers into holes at front. The first 3 fix lower moulding to metal on column but do not fix the switches. On mine (a '91, spaniard) the switch blocks are seperate (left and right) and each is fixed to the bracket on column using 2 more cross-head bolts (about M4 again, guess) - these go through the plate on column into blind threaded holes in switch block.
my switches are one lump so looks like i need a upper steering column good old p/o bodge
