wheel bearing
- donkeychomp
wheel bearing
Going to be changing the front wheel bearing tomorrow, it sounds awful! Anyone done this and have any tips on how to do this with the minimum of fuss?
Re: wheel bearing
Cancel that post I just wrote, I was talking about SJ bearings - they are dead easy!
Re: wheel bearing
Easy job as far as I know, that is if you have the correct socket
And a bunch of other ones to tap things in
Um, maybe an impact driver for the screws. Hydraulic press ?
Think I'll shut up now.
- donkeychomp
Re: wheel bearing
Sod it. Big Fucking Hammer and some beer will have it done in no time...
Famous last words...
Re: wheel bearing
The locknut is dam tight!
Robbed this lot from the workshop manual.
Hope it shows all right as I cropped loads of bits and joined together
- Vitara front wheel bearing fitting.jpg (1.54 MiB) Viewed 6377 times
- donkeychomp
Re: wheel bearing
click on real dimensions
Then click on real dimensions again
Should now be original size
- donkeychomp
Re: wheel bearing
Can someone tell me why my Vit has SJ hubs? It uses a taper bearing instead of a Vitara sealed unit roller bearing. Very confused here (that's not hard to do, really). Ordered an SJ bearing will arrive tomorrow morning.
- WP_20140903_027.jpg (1.09 MiB) Viewed 6347 times
Re: wheel bearing
Well that confused me too. So I've spent ages searching and some don't have a sealed unit, however it appears to have a one piece outer race and you don't have to set up the pre-load like an SJ ??
So I can see the locknuts dam tight either way.
My SJ has 2 separate taper roller bearings spaced apart, 2 outer races - 2 inner races.
[youtube]https://www.youtube.com/watch?v=wS21v_oUSfA[/youtube]
So are all Vitara's fitted with a 3 piece bearing ???
Some just sealed, so considered 1 piece ???
"O" how am I going to sleep now...........
- donkeychomp
Re: wheel bearing
As far as I figured it Vits have one piece cylindrical bearings, front ones anyway. The ones off my Vit are, once again as far as I can tell, are SJ413 ones. Ordered them using the number stamped on them so they are SJ. So why oh why put those hubs on a Vitara? Only reason I can think of, apart from having some lying around therefore free, is to use the discs. SJ's have pretty big front brakes, not sure how big Vitara one's are.
Still bloody confused.
