rotten sills
rotten sills
I have now discovered my sills are totally rotten. Is it easiest to cut out the rot and replace with box section and if so what size? thanks.
Re: rotten sills
I used 100x100 mm box, but not the easiest to weld thick box to bodywork
Re: rotten sills
Get the tyres size you want then do sills as once it's on it's a pig to cut
Re: rotten sills
Thanks Robbie. I didnt even think about tyre size! Im very new to all this..its my 1st build/renovation.
Re: rotten sills
Re: rotten sills
Looking good Jordi....shame you dont live nearer! :-)
Hope i can get it something like that...think i need some patience and practise.
Re: rotten sills
Re: rotten sills
They look good scottiej. Im a bit overwelmed with it all. Im trying to do one bit at a time but i keep seeing everything else!! Definitely prefer the box section but it does seem to be a lot of agro!!
Re: rotten sills
People have done some pretty tidy tube sills in the past as well
Re: rotten sills
Box section sill are relatively straight forward as body work go's. When i did mine it was the first time i had welded anything ever! I used 90x90 box section.
![Image](http://i982.photobucket.com/albums/ae304/CaptainWhiteStar/006-1.jpg)
![Image](http://i982.photobucket.com/albums/ae304/CaptainWhiteStar/008.jpg)
![Image](http://i982.photobucket.com/albums/ae304/CaptainWhiteStar/IMG_1212.jpg)
