hi i need help i have a suzuki sj 413 with su hif44 carb i have the right neadle and spring got from froum on hear i have replaiced fuel pump fuel filter condencer diss cap roter arm ht leads coil spark plugs fuel line under boniet it will go 150 yards then die fuel fitter half full need help please any idears please
All done hit in the green lanes tonight
sj 413 wont go
sj 413 wont go
Re: sj 413 wont go
could be that the tank breather is blocked... try running it with a fuel cap off and see if it makes a difference
Re: sj 413 wont go
i will go and try that now and let you know thanks
Re: sj 413 wont go
That did not work I have just bourght a tank from scrap yard put on tomarrow
Re: sj 413 wont go
Have you got a fuel filter in the engine bay or the original on the back of the chassis? or both?
Is the carb plumbed in correctly?
Does it tick over ok?
Was it runing ok before you put the su carb on it?
- timwilks13
- SCUK Website Padawan
Re: sj 413 wont go
if you can get hold of a compressor i would disconnect all fuel pipes and blast them through to be sure they're not blocked.
Also do you have the SU fuel overflow hooked up to the original fuel tank return? I had a similar thing and just pulled that pipe off and it was the issue. Have you got a picture of your SU?
Re: sj 413 wont go
It could well be that there is muck, sediment or rust in the fuel tank. When the pump is not running it will fall away from the pickup in the tank then as soon as the pump sucks fuel gets sucked into the pickup pipe blocking it and causing fuel starvation. Fitting a used tank might make matters worse as it could well have a build up of rust if it has been laying around empty. An old trick is to put a load of pebbles into the tank and give it a good long shake around to dislodge the rust before fitting it.
Re: sj 413 wont go
I Have had problem since I had the sj that is why I put su carb on and took Webber carb of I have pic how do I up load them and I think it is pick up pipe let you all know as have just got air line throu it and weldering wire I am about to put back on let you all know how it gos thank you all for ideas and help
I have put tank back on but would not start it all ways starts normally I think it is flooded will take plugs out and start it tomorrow pick up pipe was blocked
