Free wheeling hub does not appear to work.
Posted: Fri Oct 10, 2014 5:38 pm
by Ian Johnson
I have an S Reg Vitara I am having problems with. When I move the manually operated free wheeling hubs from Free to Lock. The passenger side operates as it should. The drivers side does not. I hear a clicking noise coming from the hub and it will not lock the hub. I have removed the original free wheeling hubs and replaced them with new free wheeling hubs and I am still having the same problem on the drivers side. Can anyone suggest what the problem is.
Any help you can give will be gratefully appreciated.
Ian J
Re: Free wheeling hub does not appear to work.
Posted: Fri Oct 10, 2014 11:53 pm
by Anton
I would suspect that the splines on the end of the halfshaft are shot.
Take the fwh off and take a photo of the splines, maybe donkeychomp or one of the other Vit fellas will be able to tell you if that's the problem.
Posted: Sat Oct 11, 2014 7:24 pm
by Rhinoman
Are they the all black hubs with 'Made in US' cast into them? if so then there is a plastic cam inside them that often breaks.
Posted: Mon Oct 13, 2014 3:24 pm
by Ian Johnson
Thank you Anton.
I will have a look at the splines on the half shaft to see if they are worn.
Posted: Mon Oct 13, 2014 3:28 pm
by Ian Johnson
Thank you Rhinoman.
I will have a look to see if made in the USA is cast into the casing. I believe the hubs are original Suzuki Type A manual hubs.
