vitara carburetor plumbing
mk1joe
Post by mk1joe » Sat Nov 01, 2014 4:14 pm
Hey guys me again.
Just gone and bought a standard vitara carburettor for my 1.6 8v. Fitted it to the engine but I'm a bit stuck on the fuel lines as the fuel pump I took the carb off is slightly different to mine. They both have 3 pipes coming out and I know what they all do. but I don't know what the pipes on the carb do ( there is 3 pipes on the carb aswell) should have concentrated more when I was taking it off. I can post pictures if needed.
Also the vitara air box rubs on my samurai bonnet. Has anyone had to overcome this problem before?
Thanks again for all the help guys
mk1joe
Re: vitara carburetor plumbing
Post by mk1joe » Sat Nov 01, 2014 8:13 pm
Out of these 3 pipes will the inlet be furthest to the top or furthest to the bottom? I think the middle one goes directly back to the tank.
Post by donkeychomp » Sat Nov 01, 2014 9:43 pm
Where does it rub? You could fit a 4u bonnet, has a bulge in it.
Post by ROBBIE » Sat Nov 01, 2014 9:57 pm
I used the SJ plenum chamber and piped to the air box, it had to have a spacer to fit the top of the carb
Post by ScottieJ » Sat Nov 01, 2014 10:58 pm
I used to run the 1.6 airbox with a 410 bonnet with the crossbrace removed and the 410 bonnet is lower than a samurai bonnet? I later swapped it out like robbie but found the 1.3 plenum doesn't properly fit and fouls the choke mechanism on on the 1.6 carb, I ended up adding a bit of tube to raise the plenum slightly to solve this.
As for the fuel lines I'm pretty sure there's a diagram on the forum somewhere that Darrell did.
Post by donkeychomp » Sat Nov 01, 2014 11:20 pm
Fowls...cluck cluck :hahaha:
Post by ScottieJ » Sun Nov 02, 2014 12:16 am
donkeychomp wrote:Fowls...cluck cluck :hahaha:
I blame fat thumbs and a small keyboard :hahaha:
Post by ROBBIE » Sun Nov 02, 2014 8:19 am
ScottieJ wrote: I ended up adding a bit of tube to raise the plenum slightly to solve this..
Yeah that's what I used for a spacer
mk1joe
Post by mk1joe » Sun Nov 02, 2014 9:47 am
Cool, I guess that's what I will have to do.
As for the fuel lines I can't find anything anywhere, so I'm going to take an educated guess and say the lowest pipe will go into the float chamber and be direct feed from the pump. Sound about right?
Post by ScottieJ » Sun Nov 02, 2014 10:24 am
Found it on Darrell's diagrams
