body lift needed? su carb
dug
Post by dug » Sat Jan 10, 2015 3:02 pm
I put a 2" body lift on my SJ, but I've now decided i don't want it.
My SU is on an adapter similar to the ebay ones. top part of carb is off awaiting spring and needle being delivered so cant see if bonnet will touch it but it certainly looks like it will.
Any idea if it will fit without body lift? at some point i'll get a proper inlet manifold
We're here for a good time, not a long time....If in doubt, Flat out!!
Re: body lift needed? su carb
Post by dan_2k_uk » Sat Jan 10, 2015 4:17 pm
It may squeeze in if its a 1.3.
The 1.6 is taller and it will foul.
Post by twiss » Sat Jan 10, 2015 6:49 pm
A samurai bonnet would help it...
Post by ScottieJ » Sat Jan 10, 2015 7:23 pm
I fitted a little bulge, however mine doesn't poke through much.
Post by twiss » Sat Jan 10, 2015 7:25 pm
That's with the proper manifold though isn't it?
Not an adapter
dug
Post by dug » Sat Jan 10, 2015 7:34 pm
yeah 1.6, looks like i'm stuck with the lift until i sort the manifold then
thanks
Post by twiss » Sat Jan 10, 2015 7:45 pm
Make sure you do get a manifold it will run better :)
Post by ScottieJ » Sat Jan 10, 2015 9:47 pm
twiss wrote:That's with the proper manifold though isn't it?
Not an adapter
Yes but my engine is mounted higher than standard.
dug
Post by dug » Sun Jan 11, 2015 9:06 am
where's best place to get a manifold and how much roughly?
Post by dan_2k_uk » Sun Jan 11, 2015 11:58 am
Look up Rockwatt and message him on here. Or find him on Facebook and message him there.
They are over £100 but make such a difference.
