hif44 carb layout
- Josh-holden
hif44 carb layout
hi, can somebody please tell me where all the pipes go on the carb? just brought the truck and its set up wrong
Re: hif44 carb layout
Look in the su carb thread in this section
- Josh-holden
i have and your pictures wont show up?
Try the fitting guide... Or here
http://www.suzukiclubuk.co.uk/diy/15-en ... conversion
- Josh-holden
all i need to know now is where the pipes go on the side, one is fuel in, one is overflow? should i blank this off? and is the other one a breather? if so should this go to the breather on top of the cam cover?
Bottom small one is fuel in. The top small one is overflow and should be vented.
Blank the bigger breather and leave the rocker cover connected to the airbox.
Vac advance goes on the filter side of the butterfly.
- Josh-holden
thanks, thats how iv got it, on my rocker cover it has two breathers a big one and a small one, do you know where the small one goes?
Probably used to go to the manifold if its a vit. I would just blank the extra one.
- Josh-holden
ok thanks. its a g16a, what's the easiest way to tell if its 8 or 16v?
I think the 16 valva has it written on it... most sure way is take off the rocker cover and count the valves.
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
5 speed box
1.5" Shackle Lift
Daymaker led lights
