no oil pressure sender hole
hi new to forum
new to off roading
just pick up a sj413 samurai its had a load of work done to it
lt has a1.6 engine fitted to it
as doing work on it i noticed there is no oil sender fitted and no hole for one
as this has been filled in
how can i fit one
thanks
new to off roading
how can i fit one
thanks
Re: no oil pressure sender hole
You got a photo of the block where it should be?
Can always buy a sender and drill and tap the block to fit it.
- donkeychomp
thanks jordi had that in mind
but not sure and can i drill any where
- donkeychomp
Aiming to be where the original was.bigjabber wrote:thanks jordi had that in mind
There should be a second take off with a bung in it near where the original is. Have you got a pic? I can't see why someone would have filled it in?
Because there are some reet special tards out there!ScottieJ wrote:There should be a second take off with a bung in it near where the original is. Have you got a pic? I can't see why someone would have filled it in?
thanks all
tried to undo the blank plug but would not move and rounded allen key hole
going to try a sandwich plate
