temp gauge drops under revs?
- robbie1985
So I changed the coolant last night, all was well until I realised that as I accelerated the temp gauge drops down to 0! Once I'm off the throttle the temp goes back up again but then as soon as I touch the throttle again it drops. Any ideas?
Re: temp gauge drops under revs?
Most probably a bad earth.
- robbie1985
I drained and pulled the rad over the weekend to do the crankshaft oil seal and had to bleed the system again and it appears to be working fine again! I did have a fiddle with lead too. So one of them helped lol
