new switches
lukey4x4
new switches
Post by lukey4x4 » Sun Jul 05, 2015 8:43 pm
new switch panel
new switch panel
new switch panel
car photo.jpg (132.16 KiB) Viewed 8645 times
lukey4x4
Re: new switches
Post by lukey4x4 » Sun Jul 05, 2015 8:47 pm
hi all I wired all my switches n stuff up today n had a slight problem I was testing all my switches out n had my fans running everything ok n went to flip my toggle for my horn n ended up in a puff of smoke lol my live wire from battery burnt out all the way 2 switch n the sj wasn't running at the time , any ideas , thanks
ianedwards
Re: new switches
Post by ianedwards » Sun Jul 05, 2015 10:49 pm
I'm no expert but sounds like you have Got a short on that circuit some where, double check, no fuse?
Ian. :)
Re: new switches
Post by Jordi » Mon Jul 06, 2015 12:17 pm
You running the horn through a relay?
ianedwards
Re: new switches
Post by ianedwards » Mon Jul 06, 2015 2:28 pm
believe it should be some thing like this, correct me if I'm wrong,
Ian. :)
lukey4x4
Re: new switches
Post by lukey4x4 » Mon Jul 06, 2015 8:22 pm
Well i replaced the wire n put a inline fuse in , it turned out i had put one of the wires on back of switch in the wrong place , so all workin , i have not used a relay lyk do i need to put one in , thanks
ianedwards
Re: new switches
Post by ianedwards » Mon Jul 06, 2015 10:08 pm
personally i would, even tho its just a horn, i know its a bit more work but its safer. even more so on, spot lights/fans etc.
Ian. :)
Re: new switches
Post by dan_2k_uk » Mon Jul 06, 2015 10:25 pm
The original wiring doesn't use one and the standard switch seems to last the test of time so doubt the current draw is too much on the standard horn.
If its done now and working I would just stick with it. In the unlikely event you burn a switch out grab a new one for a few quid of eBay and start again with a relay.
ianedwards
Re: new switches
Post by ianedwards » Tue Jul 07, 2015 11:19 am
:thumbup:
Ian. :)
lukey4x4
Re: new switches
Post by lukey4x4 » Thu Jul 09, 2015 9:45 pm
Thanks lads , yea think i will leave it then if it goes wrong i will start agen with a relay , thanks
