sj rear axle input shaft oil seal
sidsuzuki2346
Post by sidsuzuki2346 » Sun Jul 12, 2015 11:29 pm
Hi everyone the rear axle input shaft oil seal is leaking on the sj, not badly but if it can be done with a basic mechanical knowhow it will sort it. Do you have the re-do the preload on the bearings or no, i spoke to the mechanic i work for and he said something about it.
Re: sj rear axle input shaft oil seal
Post by dan_2k_uk » Mon Jul 13, 2015 10:17 am
You mean the pinion oil seal where the propshaft connects to the diff?
If so then yes the diff will need preloads etc doing using a new crush sleeve to get it setup correctly again.
Might well be the case that it's leaking because the pinion bearing is worn anyway.
sidsuzuki2346
Post by sidsuzuki2346 » Mon Jul 13, 2015 5:05 pm
Might just change the whole back axle then cause I've got another sj for bits. Cheers
